LMS 3.0 and IPM
scootertgm
We had IPM running under 2.5. I see that the interface has drastically changed. I've been trying to setup a collector and a target and I keep getting a host not responding. I have tried several different sources and keep getting the same error - Source not responding.
Any ideas?
Default credentials have no bearing on devices already in DCR. You will need to select the device from the Device Management selector, and click Edit Credentials. Then fill in the correct credentials for that device.
Joe Clarke
Check DCR to make sure the SNMP credentials are correct for your source. IPM relies entirely on DCR now for all source devices and their credentials.
Good call on where to start. The default credentials were blank. Must have gotten wiped out in the upgrade.
I entered the SNMP and the device credentials (The ACS user ID and Password for CW).
Still getting source not responding
That did it Thanks!
