LMS 3.2 - how to reset DFM Database
Hey experts,
I want to reset my DFM database, because there are many entries of (now) unmanaged devices.
So how can I do this correctly on LMS 3.2 without touching the other databases.
I found the following thread in this Forum (https://supportforums.cisco.com/message/694414#694414)
It say´s to do the following steps:
Stop the daemons
cd CSCOpx\bin
perl dbRestoreOrig.pl dsn=dfmEpm dmprefix=EPM
perl dbRestoreOrig.pl dsn=dfmInv dmprefix=INV
perl dbRestoreOrig.pl dsn=dfmFh dmprefix=FH
restart the daemons
Can I use this commands in LMS 3.2, too ?
Anything else to do?
Btw. we use the windows version of LMS 3.2.
thx,
Patrick
David Stanford
In addition to these commands, go ahead and delete or rename the following files:
NMSROOT/objects/smarts/local/repos/icf/DFM.rps
NMSROOT/objects/smarts/local/repos/icf/DFM1.rps
David Stanford
Hey davistan,
thank you. It worked wonderfully =)
The only thing I had to do after all this steps was to re-install the database access.
The command for this is: \NMSROOT\bin\perl dbaccess.pl install
Summary for all other Users:
net stop crmdmgtd
go to NMSROOT\objects\smarts\local\repos\icf\ and delete the following files ( I even deleted all the other files in this directory )
DFM.rps
DFM1.rps
go to NMSROOT\bin
net start crmdmgtd
go to NMSROOT\bin
Bye,
Patrick
