lms 3.2 in high availability mode with veritas solution: installation error
Hi!
i`ve tried to install lms on two windows 2003 servers R2/SP2 in according to guide (Chapter 4 Setting Up CiscoWorks LMS in High Availability and Disaster Recovery Environment http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/install/guide1/hasetup.html). When i launch the LMS install shield, after self-signed certificate confirmation step i am getting this error:
An Error (-5011 : 0x80040705) has occured while running the setup.
Please make sure you have finished any previous setup and closed other applications.
If the error still occurs, please contact your vendor: Cisco Systems Inc.
Error Code: -5011 : 0x80040705
Error Information:
>SetupNew\setup.cpp (488)
PAPP:CiscoWorks
PVENDOR:Cisco Systems Inc.
PGUID:11B8350D-559C-45BE-8EDC-A7B2DA265F7F
$15.0.0.603PAK
@Windows Server2003 Service Pack 2 (3790)
IE Version: 6.0.3790.3959
Joe Clarke
I don't think this is a problem with HA, but rather a known bug with the OpsXML installation (CSCte84743).  Open a TAC service request as development would like to analyze a server experiencing this problem in real time.
