LMS 4.1 - Direct Deploy with advanced dependency fails
hgans
I am trying a deploy template under LMS 4.1 based on a discussion here in the community.
There is always a strange error message, a simple default template (e.g. deploy of SNMP RW community) works fine on the same device, so this cannot be true:
*** Device Details for LMS-Test ***
Protocol ==> Unknown / Not Applicable
Selected Protocols with order ==> Telnet,SSH
Execution Result:
CM0150 Deploy Baseline template to PRIMARY config on device failed Cause: CM0070 Copy Config to device failed on LMS-Test Cause:
Could not detect SSH protocols running on the device
Action: Check device credentials and reachability.
CM0089 Config archival successful for LMS-Test
I am sure the credentials are ok, below the template I try to run on a switch.
It checks for a certain description content and shall push some command into this interface... seems to work for other people.
Template: CheckDescr
Sub-mode: [interface #FastEthernet.*#]
Is Prereq: Yes
Body:
+ [#description .*DEFEKT.*#]
Template: NoLinkStatus
Parent: CheckDescr
Prereq: CheckDescr
Body:
+ no snmp trap link-statu
thanks for any help!
hgans
Seems I found the cause of my issue...
A compliance check job needs to be created with above template example and in this job the direct deploy option must be checked.
Direct Deploy without compliance check simply doesn't...?
