LMS 4.2 forward traps to Netcool
rdasiman
We want to forward LMS 4.2 traps to a remote NMS (Netcool).
In order to translate the traps into an event, we need the MIB's which LMS 4.2.3 is using.
Does anyone know the location of the directory on the LMS server of these MIB's?
AFROJ AHMAD
you can forward the traps directly  from here : Monitor > Fault Settings > SNMP Traps > Notification
check this location on the server:
NMSROOT\CSCOpx\hum\mibmanager\mibcompiler\mibs
If you want to add a new MIB to LMS , you can LOAD the MIB to the server from here :
Admin > Network > Monitor / Troubleshoot > Load MIB
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
