07-04-2012 11:35 PM
Hi all,
I was wondering why LMS 4.x isn't able to fully integrate ACS v5.x Device in Inventory.
We added our ACS-Applicance (plz see show ver)
Cisco Application Deployment Engine OS Release: 1.2
ADE-OS Build Version: 1.2.0.228
ADE-OS System Architecture: i386
Copyright (c) 2005-2009 by Cisco Systems, Inc.
All rights reserved.
Hostname: A1
Version information of installed applications
Cisco ACS VERSION INFORMATION
Version : 5.3.0.40
Internal Build ID : B.839
but only little integration was possible (no detailed inventory, no config fetch, ...)
SNMP-OID was discovered as non-cisco (Prime Computer)
dcrcli> detail id=3642
Display Name = A-1, Device ID = 3642
MDF Type : Unknown Device Type
Sys Object ID: 1.3.6.1.2.1.47.1.1.1.1.13.1
IP Address: 10.100.207.11
Host name: A-1
Domain name: xxx.net
Primary Username: <Value specified>
Primary Password: <Value specified>
Primary Enable Password: <Value specified>
SNMP V2 RO Community String: <Value specified>
SNMP V2 RW Community String: <Value specified>
No Inventory-Packages are available via CCO to download.
Does anybody of you out there know whether there are any plans to fully integrate ACS devices?
In our Company ACS will be used for 802.1x authentication, and is quite important.
So we would like to fully manage this Cisco-Device with Cisco's element management tool available (LMS)!
Thanks for any feedback
Lothar
07-05-2012 04:16 PM
Cisco Prime LMS is not designed to manage appliances like the ACS. ACS is not on the LMS supported device list and I would doubt that it would be as LMS's functions are mostly not applicable to the appliance or software running on it.
You can use ACS as an authentication source for LMS, but authorization is still role-based according to the local accounts on the LMS server.
