LMS CiscoWorks 3.2 CPU 100 % on devices monitored
m.arienti
HI,
it's possible that LMS CiscoWorks influenced devices performance? On devices monitored from CiscoWorks CPU reached peaks of 100% of utilization.
If i stop Ciscoworks they work normally.
Joe Clarke
Yes, it is possible.  Device bugs can exist that cause high CPU when certain MIB objects are polled.  There may also be other factors that can lead to high CPU when a device is polled with SNMP.  For example, routers will large ARP caches may see CPU spikes when User Tracking polls the devices during acquisition.  In these cases, SNMP views can be applied to restrict those MIB branches from being polled.
To determine what MIB objects are leading to CPU spikes, the output of "show stack PID" is required when the CPU is spiking (where PID is the process ID of the SNMP ENGINE and IP SNMP processes).  In addition to this, the show version and show region output are required.
I think the problem is caused by the job inventory polling because if that job doesn't start the problem about CPU doesn't appear.
Someone know how to make this job "light" for the devices?
There's no way to change what Inventory Polling does.  The "show stack" output would still be needed to determine what SNMP object is causing the CPU spikes.  From there, SNMP views can be applied to restrict access to prevent the spikes.  This would be a workaround.  A bug would need to be identified to fix the CPU spike.
