LMS Port-Security on a Catalyst switch WS-C2960-48TT-S
silviugolo
I cannot configure port-security from the ChasisView component of LMS,
on a WS-C2960-48TT-S switch. When I select "Port Security..." from the
"Category" combobox, I get this error message:
Can not Configure Port Security Because Dynamic Port
I have updated ChasisView with the latest .zip file from here
http://www.cisco.com/cgi-bin/Software/CiscoView/cvplanner.cgi
but I'm still getting this error message.
The configuration of the interface, on which I'm trying to set port security this is below
(so there are no dynamic settings):
interface FastEthernet0/9
switchport access vlan XXX
switchport mode access
Thanks for any hints/help!
CiscoView
Version & Patch  Level: 6.1.9
Active Device Package: Catalyst 2960 Device  Package(6.0)
Joe Clarke
This is most likely a device problem.  A similar bug was opened for 6500s (        CSCsv63323), but it was closed since the problem was due to buggy IOS code.  What version of code is the 2960 running?
Hi Joe,
It's Version 12.2(46)SE.
Thanks!
System image file is "flash:/c2960-lanlite-mz.122-46.SE/c2960-lanlite-mz.122-46.SE.bin"
