Netconfig Job errors
ddalessa
I am having a problem lauching a basic Netconfig job to simply remove and adding a few usernames to our routers. The job fails on a considerable amount of routers where previously, we did not have any issue at all. Looking at the job details, the errors fall between 2 types:
Could not establish telnet session to device: :PGM_NM=Configuration Archive:6739:TYPE=unassigned message type::Invalid login password.
OR
Could not establish telnet session to device: :PGM_NM=Configuration Archive:6727:TYPE=unassigned message type::Invalid TACACS user name and password.
In each instance, I have tried removing the TACACS user fields, as well as ensuring the login accounts are correct. To simplify things, I picked a single router which I am having difficulty with. I deleted all the fields and re-entered them. Yet, the job continues to fail with the same message. I opened a ticket with Cisco, have explained the same to them, and await a moment where we can essentially pick a router and re-do the same thing.
Has anyone else experienced such a thing ?
Dan D'Alessandro
David Stanford
Are the TACACS prompts on the device anything other than Username: and Password: ? If you have customized them have you edited the TacacsPrompts.ini file?
It might also be interesting to run a packet capture for a single device in a job to see what info it contains.
