Network Analysis Module
mohiuddin3
Hi,I want to delete the data stored by the datasources like SPAN,RSPAN and Netflow.I tried with deleting the datasources and also used the commands "config clear", "config clear all". But this did'nt worked.
Secondly I need to synchronize the time of NAM with that of Switch or NTP Server. I have tried this with the NAM GUI as well as CLI but the time is not changing. There is a difference of 10 hours between the NAM and switch.
didyap
Level 6
Level 6
You can set NAM time to sync with NTP server with the following NAM CLI command:
time
sync ntp
zone
exit
