Numerb of Archive
oalvi
How to limit the Number of configuration visions of device in RME 4.0.4 CW Lms 2.5
miheg
Level 5
Level 5
Enable the purge setup in RME -> Admin -> Config Mgmt -> Archive Mgmt -> Purge Settings
Check the "Maximum number of versions to retain"
and enter the number of config you wish to keep
Cheers,
Michel
miheg
Level 5
Level 5
Cheers,
Michel
