Plotting inbound and outbound traffic to a specific network with Cacti or Mrtg
firmanperdi
Hi Guys,
First of all, pardon me if i post on a wrong sub forum.
So, I have a question about the methods to plot inbound & outbound traffic to a specific network, as you can see the topology below :
We have a Cisco 7609 as the Router Edge and 2 Uplinks to different ISPs. As by now I'm wondering is there any methods to mark inbound traffic from both ISP A and ISP B for a specific network ?
For example : Is it possible to plot traffic that only going to network 202.138.1.0/24 from the Interface to ISP A with cacti or MRTG ?
If it possible, what method to use ?
Is it something to do with DSCP ? As far as I know that DSCP does marks the packets. But then, what to combine with this DSCP, so in the end I can generate OIDs to Plot ?
I'm sorry for my english, I hope you guys understand what I'm trying to ask here.
Cheers !!
Seb Rupik
Hi there,
This a perfect example of a problem best solved with a netflow collector. I've been using an opensource tool called nfsen and would recommend that.
http://nfsen.sourceforge.net/
You would need to configure a collector on each router-ISP interface. These would export to different ports on the collector giving two different concurrent flow sources.
On nfsen as well as displaying an aggregate of all flows from a collector, you can also configure 'profiles' which display a live graph on a filtered subset (in your case 'net 202.138.1.0/24') of the flow data and allow you to run further queries on.
cheers,
Seb.
Seb Rupik
Hi there,
cheers,
Seb.
Hi Seb,
Thanks for your reply, I'm currently doing some search about NFsen and seems like it is not too hard to configure. So, I'll give it a try.
I hope this works.
Thank you !
