Prime Infrastructure 2.1. Configuration template deploy problem.
DOM.RF NOC
Hello! I have a problem with the CLI template deployment on Cisco Prime. PI version is 2.1.
There is the following template, which contains:
logging on
logging 10.10.10.10
When I try to deploy it on the router 1800 IOS Version 12.3(14)T7 all is going well and the report I get the following:
Device
Status
Transcript
10.5.5.1
Success
configlet: logging on logging 10.10.10.10 response: terminal width 0 config t logging on logging 10.10.10.10
But, when I try to deploy the same template on the router 3825 IOS Version 15.1(4)M5, the system issues the following error:
In what may be the reason that Prime cannot deploy the configuration on IOS version 15.1?
Thank you!
Saurav Lodh
Level 7
Level 7
I see similar issue over here , please refer
https://supportforums.cisco.com/discussion/12114651/prime-infrastructure-cli-template-smartport-macro
Good day! Yes, maybe we have the same BUG
https://tools.cisco.com/bugsearch/bug/CSCub57283
but in the status written that it is Fixed and applies to releases 1.2 and 2.0, but we used version 2.1.
