Prime LMS 4.2.2 CiscoView Question
Dawit Zeru
Hi everyone,
I have a Question,
Can I change interface Vlan ID from the CiscoView?
for example I want to change interface  G1/1/1 in Vlan 1 to Vlan 2 from CiscoView?
thanks
Vinod Arya
Yes, this can be done via CiscoView.
But it is only possible for the Switchport ports/interfaces. You can right click on the interface and click configure and go to physical to do this.
See the attached picture.
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
