Problem with Track not being recognized by EEM (Event Manager Applet), not showing as "Tracked By"
dblagbro
So when I run "show track 2", nothing shows up as "Tracked By" even though it's the trigger for an EEM Applet, but my "show track 1" shows that it is being tracked by static routes.
I can see that the EEM App is not triggering / running (using it to send an email).  It worked once upon a time, but I noticed I stopped getting emails over the last couple months but not sure exactly when.
Key pieces of "show run":
track 2 ip sla 2
delay down 5
ip sla 2
icmp-echo 24.XXX.XXX.1 source-interface GigabitEthernet0/0
threshold 500
timeout 1000
frequency 1
ip sla schedule 2 life forever start-time now
event manager environment _email_to XXXXX@gmail.com
event manager environment _syslog_msg
event manager environment _email_from XXXXX@earthlink.net
event manager environment _email_server :XXXXX@smtpauth.earthlink.net 587
event manager applet ISP_change
event track 2 state any
action 0.5 cli command "enable"
action 1.0 cli command "clear ip nat trans *"
action 1.5 wait 10
action 2.0 mail server "$_email_from$_email_server" to "$_email_to" from "$_email_from" subject "On SAT / Cable Down Change - $_event_pub_time" body "Event ID: $_event_type /// Cable is now: $_track_state." source- interface GigabitEthernet0/1
action 2.5 end
end
(EOF)
I am using 2 tracks, one for IP routing and this track 2 for notifications....
Now when I run, show track 1, I get the "Tracked By" - as it should be but for this track 2, I get nothing:
router#
router#show track 2
Track 2
IP SLA 2 state
State is Up
2 changes, last change 16:16:27
Delay down 5 secs
Latest operation return code: OK
Latest RTT (millisecs) 8
router#
router#
I am not sure why my "show track 2" isn't showing the applet that should be tracking it. Any guidance appreciated... I've tried newer code - it's a C3945 with latest MR software on it but happened with some older IOS too.
Following someone else's suggestion I ran "show event manager history events" which returns nothing (I presume implying it's not been run - but it's also not in my logging and running "debug event manager all" doesn't show anything about this event applet either).
dblagbro
So someone was able to point out the issue:
The EEM applet / script was not compiling properly because their was an "action outside of conditional block."
In other words, this line " action 2.5 end" was not relevant, prevented the compilation so therefore the script was invalid and therefore "track 2" was not actually being tracked.
Removing that line, existing the script context and writing-mem caused it to start working.
dblagbro
