Public links
Ibrahim Jamil
Level 6
Level 6
Hi Experts
i m looking for the public below links since i don't have CCO account to read this as i got "forbidden"
1. Use the Reporting features in LMS 4.0 to generate a 24 hour syslog report to view all the syslog info from the devices.
http://www.cisco.com/en/US/partner/docs/net_mgmt/ciscoworks_lan_management_solution/4.0/user/guide/Reports/fault_even_reports.html#wp1265904
2. First create user defined groups and five different discovery jobs based on the user defined group categories.
Step 1: Creating "User Defined Groups":
http://www.cisco.com/en/US/partner/docs/net_mgmt/ciscoworks_lan_management_solution/4.0/user/guide/admin/groups.html#wp1185351
I would name each UDG based on their regions or you can do it like stated above "CampusA", "CampusB", "CampusC", "CampusD", and "CampusE". The idea to is come up with a consistent naming convention that applies to your environment and create a rule based on the subnet or device type.
Step 2: Create multiple discovery jobs for different Campuses with different settings based on subnet range:
http://www.cisco.com/en/US/partner/docs/net_mgmt/ciscoworks_lan_management_solution/4.0/user/guide/admin/dcr_adm.html#wp1103132
3.  5520 is supported with 7.2(1) or higher. See device matrix:
http://www.cisco.com/en/US/partner/docs/net_mgmt/ciscoworks_lan_management_solution/4.0/device_support/table/lms40sdt.html
4. LMS is your NMS server and will handle the SNMP traps through its Fault Management feature in the application.
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps11200/deployment_guide_c07-618226.html#wp9001130
Hi Marvin
thanks for ur info
am still receiving forbidden even with the customer keyword
http://www.cisco.com/msgs/403.html#
can u help me in the below!
2)how can i delete a device from the DCR?
3)my LMS ping the ASA  and Correctly i have entered the SNMP community exist the asa but it gives me errors so please help me to the asa to my cisco works ,
thanks
