Single point setup WAP150 doesnt work
Hello, i have a problem.
I have several WAP150 in our complex, and i did the single point setup, at first it worked but now i get the following errors, :
rror occured for query on path cluster.NodeStatusMonitor.getStatus (function: data_service, file: /home/sam.you/project/torrey_pines.git/ap/broadcom/src/web-ui-framework/data_service.c, line: 481)
   activator_execute: connect to /var/clusterd.socket failed: Connection refused (function: activator_execute_buffer, file: /home/sam.you/project/torrey_pines.git/ap/broadcom/src/web-ui-services/activator_query.c, line: 67)
error occured for query on path cluster.member.get (function: data_service, file: /home/sam.you/project/torrey_pines.git/ap/broadcom/src/web-ui-framework/data_service.c, line: 481)
error occured for query on path cluster.cluster-firmware.get (function: data_service, file: /home/sam.you/project/torrey_pines.git/ap/broadcom/src/web-ui-framework/data_service.c, line: 481)
Can enyone help with this problem??
0 Replies 0
