SNMP monitoring of PRI Channels on MGCP Voice Gateway Router
swharvey
Level 3
Level 3
We are running Cisco 2821 and 2851 routers with the voice gateway ios bundle. The routers are MGCP based gateways, and we cannot monitor the PRI T1's "active calls" via SNMP polling. We are able to monitor the calls via the Call Mgr Real Time Monitoring Tool (RTMT) but we need to post graphs to our RRD Remstats system. Are there specific OID's or MIB's that can be defined to glean this data from the routers?
Thx
David Stanford
To get just the count of VoIP active calls the simplest way is to count
the number of entries that you get in the object cvVoIPCallActiveTable.
Sometimes this may not be accurate so it is good to verify that for each
entry in cvVoIPCallActiveTable, there is an entry in callActiveTable. If
not, drop those ones from the count.
To further refine this to distinguish between calls that are in
connecting, connected or active state you can use the
callActiveCallState in callActiveTable.
The oid used above are as follows :
CISCO-VOICE-DIAL-CONTROL-MIB: "cvVoIPCallActiveTable"
"1.3.6.1.4.1.9.9.63.1.3.2"
DIAL-CONTROL-MIB: "callActiveTable"
"1.3.6.1.2.1.10.21.1.3.1"
DIAL-CONTROL-MIB: "callActiveCallState"
"1.3.6.1.2.1.10.21.1.3.1.1.9"
Also for Historical data, the following looks promising :
CISCO-VOICE-DIAL-CONTROL-MIB: "cvCallHistoryTable"
"1.3.6.1.4.1.9.9.63.1.4.1"
-----B------
To get something similar to the information of the command "sh call
voice active brief" you could do something like what I have below: (have
provided the MIB info next to it, for easier understanding)
H323 leg
pid: pid:200
callActivePeerId.291909790.1 = INTEGER: 200
Answer
callActiveCallOrigin.291909790.1 = INTEGER: answer(2)
205
callActivePeerAddress.291909790.1 = STRING: 205
active
callActiveCallState.291909790.1 = INTEGER: active(4)
tx:/ tx:85515/13681843
callActiveTransmitPackets.291909790.1 = Gauge32: 85692
callActiveTransmitBytes.291909790.1 = Gauge32: 13710323
rx:/ rx:85441/13670560
callActiveReceivePackets.291909790.1 = Gauge32: 85621
callActiveReceiveBytes.291909790.1 = Gauge32: 13699680
For the Telephony leg
pid:1
callActivePeerId.291909815.1 = INTEGER: 1
Originate
callActiveCallOrigin.291909815.1 = INTEGER: originate(1)
93928027
callActivePeerAddress.291909815.1 = STRING: 93928027
active
callActiveCallState.291909815.1 = INTEGER: active(4)
tx:/ tx:85442/13670720
callActiveTransmitPackets.291909815.1 = Gauge32: 85619
callActiveTransmitBytes.291909815.1 = Gauge32: 13699360
rx:/ rx:85515/13681843
callActiveReceivePackets.291909815.1 = Gauge32: 85695
callActiveReceiveBytes.291909815.1 = Gauge32: 13710963
We are also looking to perform some call management leveraging this information as you described in your post.  With voice gateways configured for H.323, the callActivePeerAddress table is filled with source and destination numbers, but with MGCP there is no details.  I see from your example that you display data from callActivePeerAddress, namely the string:  93928027.  What would be the reason this table is empty for us with MGCP, but not with H.323?
