SSL handshake failed
hazelrichardson
I am running Ciscoworks LMS 2.6 and am getting periodic Apache.exe failures which is crashing Ciscoworks. In the error.log file I am also seeing the following output:
[Tue Jun 03 06:26:49 2008] [error] mod_ssl: SSL handshake failed (server <server IP>, client <server IP>) (OpenSSL library error follows)
[Tue Jun 03 06:26:49 2008] [error] OpenSSL: error:140A1041:SSL routines:SSL_BYTES_TO_CIPHER_LIST:malloc failure
We are running OpenSSL version 0.9.7i 14 Oct 2005
Do you have any suggestions as to what is causing this? Thanks.
Joe Clarke
What version of Common Services do you have?
hazelrichardson
we are running 3.0.5 of Common Services
