Syslog purging do not work with RME 4.0.4 and CSM 3.0.1
anton_zyablov
I purge syslog database in RME.
Default job indicate success, also I make force purge, it is success too, but size of RME syslog database don't change!
smahbub
Level 6
Level 6
NMSRoot\lib\jre\bin\java -cp "location where the attached class file is
stored";NMSRoot\lib\classpath;NMSRoot\www\classpath;NMSRoot\MDC\Tomcat\w
ebapps\rme\WEB-INF\classes\;NMSRoot\MDC\tomcat\webapps\rme\WEB-INF\lib\l
og4j.jar DBSpaceReclaimer
Note: Replace NMSRoot with appropriate path.
Restart daemon manager after completion of above task.
