USING SNMP FOR FETCHING RUNNING CONFIG
prasad.gsmc
I dont have access to a router. But I have SNMP read write permission. I am equiped with an SNMP r/w community string. Is it possible to view the running configuration using SNMP polling using any specific MIB? Please help me in this.... Thanks in advance
You will have to transfer the configure using a protocol such as TFTP or RCP. You will not be able to see it with SNMP alone.
Joe Clarke
Yes, this is possible. See this tech tip on how to fetch and deploy configurations using SNMP and the CISCO-CONFIG-COPY-MIB:
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_configuration_example09186a0080094aa6.shtml
Thanks for the reply,
I would prefer to View the config on the SNMP tool console? COz We cant export to TFTP server since there is a firewall in between... any hope? Or i will try to set up a TFTP server
