Using the Cisco product license registration portal
matt.ambitec
Hi, I want to add a DATA license pak to a Cisco 1941 router. I bought the router second-hand (although it's only a few months old) and I don't at present have any support contract or even warranty info. Will I be able to use the License registration portal as a Guest user to obtain a license file for the router (assuming I have a valid SL-19-DATA-K9 PAK)? Based on what I have read and looked up it seems that this should work, and certainly, say, using the 'call home' method. If anyone can verify this for me I'd be very grateful. Thanks.
Marvin Rhoads
You will have to have a cisco.com userid to use the portal.
However, you do not need to have any support contract entitlement associated with your account or the device.
You will need the license PAK and device serial number.
Thanks, very much appreciated.
