VMS Monitor Center Error
llacquaniti
I've a problem with a VMS2.2 on Microsoft platform: I installed a Cisco VMS2.2 bundle several mounth ago and all works fine. Last week I get that error using Monitoring Center:
"The list of monitored device could not be loaded from database - java.lang.NullPointerExcepion",
but the Management Center seems to have no problem.
Thanks in advance
Luigi
amritpatek
Level 6
Level 6
From the message, it seems that the database got corrupted. Probably, the transaction log file from the secmon/idsmc database got deleted. Easiest to get it repaired is, if you reinstall the IDSMC/Secmon.
I just installed the IDS-MDC 2.0.1 (first you must uninstall the old version, else it doesn't works) and all works fine (of course I lost all old logs).
Luigi
