Zabbix is unable to fetch Running config from switch
HCL-Network
Hi All,
Please note that Zabbix is unable to fetch running config from cisco switch.
Can anyone please help?
@HCL-Network what errors do you get/see?
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Hi @bigevilbeard
Below is the error
inconsistentValue (The set value is illegal or unsupported in some way)
Failed object: iso.3.6.1.4.1.9.9.96.1.1.1.1.14.1
are you using a shell script ? If so, post the entire .sh script...
The error message inconsistentValue (The set value is illegal or unsupported in some way) suggests that there's a problem with the SNMP OID (Object Identifier) being used to retrieve the running configuration. Use the Zabbix snmpwalk command to test the OID directly from the Zabbix server.
