API calls for Device IP/DHCP settings
TWDave
Community Member
Hi there I am currently using power bi to gather info using the meraki API and i am trying to get device info. I get all the info i require except the only things i can't find is getting the setting for the IP if it is using DHCP or static .
this is the last bit of info i need in my report to save me going through each and every device as i am taking the admin over from the original engineer who has now left the conmpany.
5 Replies 5
thanks for that not much use though
I just want to query is the management IP of the APs static or DHCP
https://developer.cisco.com/meraki/api-v1/#!get-device-management-interface
You just need to know the serial number of the device...which you get a couple of different ways...
https://developer.cisco.com/meraki/api-v1/#!get-network-devices
or
https://developer.cisco.com/meraki/api-v1/#!get-organization-devices
You can search the model or a device tag to look for the AP's.
TWDave
Community Member
Thanks ww proper kind of awesome reply right there
