Get Network Devices, deprecated - replacement?
What In the
Level 3
Level 3
I see that "Get Network Devices" is now deprecated
https://developer.cisco.com/meraki/api-v1/get-network-devices/
does "Get Organization Devices" replace it?
https://developer.cisco.com/meraki/api-v1/get-organization-devices/
7 Replies 7
aleabrahao
Meraki Community All-Star
No, you have to use this one.
https://developer.cisco.com/meraki/api-v1/get-device/
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
obrigg
Meraki Employee All-Star
Yes.
https://developer.cisco.com/meraki/api-v1/deprecated-operations/
We will get this page to be linked to the deprecation banner, so people won’t need to find it themselves.
SWeidner11
Level 2
Level 2
Yes. If you want only one Network, the response can be filtered by including the Network ID in the query.
Thank you Steve.
Would that look something like this?
devices = dashboard.organizations.getOrganizationDevices(
organizationId=organization_id, networkIds=[network_id]
Yes, that code snippet works for me.
Edited to be more specific.. Unless "network_id" is defined somewhere else in your code, you'll need quotation marks around the Network ID, so..
organizationId=organization_id, networkIds=['network_id'])
Thanks!
aleabrahao
To be honest, I think both work. Have you tried them?
Thank you! You always are very helpful.
I have not tried it yet. reading up on how to filter the net ID then get the port info I need.
