Help with Meraki-CLI to update firewall rules
NetEng11
Community Member
Here's my argument:
meraki appliance updateNetworkApplianceFirewallL3FirewallRules --networkId <networkID> --kwargs "{
"rules":[
"comment": "Block",
"policy": "deny",
"protocol": "any",
"srcPort": "any",
"srcCidr": "any",
"destPort": "any",
"destCidr": "<IP.ADDR>/32",
"syslogEnabled": false
Trying to update firewall rule to block an IP for multiple sites but get following error:
2025-02-14 12:41:25,820 [CRITI] Error loading JSON kwargs. Check syntax.
2025-02-14 12:41:25,820 [ERROR] Expecting property name enclosed in double quotes: line 3 column 5 (char 7)
Traceback (most recent call last):
File "/home/sgre/.local/share/pipx/venvs/meraki-cli/lib/python3.12/site-packages/meraki_cli/__main__.py", line 466, in _get_method_params
kwargs = json.loads(kwargs_value) # Interpret the JSON
File "/usr/lib/python3.12/json/__init__.py", line 346, in loads
return _default_decoder.decode(s)
File "/usr/lib/python3.12/json/decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/lib/python3.12/json/decoder.py", line 353, in raw_decode
obj, end = self.scan_once(s, idx)
json.decoder.JSONDecodeError: Expecting property name enclosed in double quotes: line 3 column 5 (char 7)
Any advise on where I have gone wrong?
aleabrahao
Meraki Community All-Star
The error indicates that there is a problem with the JSON syntax in the arguments (kwargs) passed to the updateNetworkApplianceFirewallL3FirewallRules command.
The specific error is: Expecting property name enclosed in double quotes: line 3 column 5 (char 7)
This suggests that there is a problem with the double quotes somewhere in the JSON.
When examining the JSON provided, I noticed that there is a space before the { curly brace that begins the rules object. This may be causing the error.
Try removing the space before the { curly brace and see if the command works:
--kwargs "{ "rules": [{ "comment": "Block", "policy": "deny", "protocol": "any", "srcPort": "any", "srcCidr": "any", "destPort": "any", "destCidr": "<IP.ADDR>/32", "syslogEnabled": false }] }"
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
Philip D'Ath
Your platform might not allow quotes to be used inside of quotes. Try making the outside ones single quotes. I think Mac is super picky about this in particular.
meraki appliance updateNetworkApplianceFirewallL3FirewallRules --networkId <networkID> --kwargs '{
Philip D'Ath
Or perhaps try using double quotes for the inside ones:
""rules"":[
""comment"": ""Block"",
"policy": "deny",
