JSONScript Body different from Dashboard GUI
DonoKoB
Community Member
Hi all, I recently just migrated a C9300 running IOS-XE to meraki software. Now I have to configure it and I plan to use Meraki RESTAPI with Postman. I downloaded the Meraki Dash API v1.49.0. I used the script for configuring network port profile.
The script variables are very different from the GUI (while configuring the same thing). My question is how to configure using this Postman ? Do I leave the value as blank ? Do I remove the name ?
Philip D'Ath
Meraki Community All-Star
Trying configuring a profile on one of the ports, and then cal the API and see what it returns.
I would expect when using a profile that you wouldn't need to specify much more than the profile name to apply.
