License Management Automation
IronBones
Does anyone have a strategy for License management that they use to stay on top of multiple networks with multiple devices?
Asking for a Very disorganized friend...that may have ADHD...
IronBones
6 Replies 6
mloraditch
Meraki Community All-Star
We are an MSP and developed a system with the API to manage our clients.
Boundless Digital has a product as well: https://www.boundlessdigital.com/product/licensing/
If you found this post helpful, please give it a thumbs up. If my answer solves your problem please click Accept as Solution so others can benefit from it.
Mloraditch,
Do you have any code you can share?
IronBones
mloraditch
I don't do the development myself and can't share our code. Sorry!
No worries and completely understand.
IronBones
jopolloc
Hi @IronBones!
Depending on how much data you need, or the method of consuming said data, it can be as simple as monitoring inbound dashboard e-mail alerts and reacting to any expired licenses prior to the grace period.
On the other hand, you could run a script that makes the API call getOrganizationLicenses and pull each expirationDate against each licenseKey, comparing them against the current date and alerting on proximity to that expiration date, or parsing the output to a CSV file for review elsewhere. There's a useful three-part guide on the community forums here that details how to use the API with Python.
If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it.
This was what I am looking for is a script someone has used to find and compare expiration to current dates. We are an MSP as well but have just enough that it is hard to keep up so I was hoping someone had tried to use the API to consolidate the info in a CSV file or email or maybe both.
ironBones
