Meraki MCP (Model Context Protocol)
fabianlevinsky
Community Member
Hi everyone, today we are excited to announce the release of our first open source project: Selent MCP - a Model Context Protocol server that provides dynamic access to the entire Cisco Meraki Dashboard API. Rather than building static tools for individual endpoints, we've engineered a solution that discovers and executes any of the 400+ Meraki API calls on demand, while also providing more complex tools for troubleshooting and analyzing the data.
You can read our full blog: https://www.selent.ai/blog/open-sourcing-selent-mcp
Github: https://github.com/selent-ai/selent-mcp
Any feedback is greatly appreciated, so please don’t hesitate to give it a try!
fabianlevinsky
Community Member
🚀 Selent MCP Update: AI-Powered API Discovery & Multi-Key Support
We're excited to announce a major update to Selent MCP (Model Context Protocol) for the Cisco Meraki Dashboard API!
What's New:
🔍 Semantic Search - Find the right API endpoint using natural language instead of memorizing exact names. Just ask "check device port configuration" or "show firewall rules" and get ranked results with 95% accuracy.
🔑 Multi-Key Support - Perfect for MSPs! Manage multiple customer organizations with a single MCP server instance. The system automatically routes API calls to the correct key based on organization context.
Key Features:
  • 816+ endpoints indexed and searchable via natural language
  • Vector-based search powered by Qdrant and FastEmbed
Works with Claude Desktop, Claude Code, and other MCP-compatible AI assistants.
📖 Full details: https://www.selent.ai/blog/selent-mcp-semantic-search-multi-key
💻 GitHub: https://github.com/selent-ai/selent-mcp
Try it out and let us know what you think!
6 Replies 6
federicoepis
Community Member
Congratulations, @FabianLevi, and the whole team, on such a great project and release - a significant contribution to the Meraki community! 👏
Jamiegprice15
Level 4
Level 4
This looks pretty good!!
Philip D'Ath
Meraki Community All-Star
Wow, very interesting.
fabianlevinsky
Community Member
What's New:
Key Features:
niklash
Community Member
Hi Fabian,
is it correct, that your MCP server currently only supports read-only API calls?
I would like to also execute simple and non-destructive changes.
Niklas
Hi Niklas,
Actually, the MCP can access all available endpoints of the Meraki API - not just read-only operations. This means it has the capability to perform POST, PUT, and DELETE operations as well.
However, if you want to restrict it to only read-only operations for safety, you can achieve this throughprompting. When interacting with the MCP, you can explicitly instruct it to only use GET operations for fetching data and to avoid making any modifications. This gives you control over how the tool is used while still maintaining access to the full API functionality when you need it.
