Monitor Devcies
Philip D'Ath
Meraki Community All-Star
It is not possible to monitor weather devices are up or down via the Dashboard API - correct?
ww^
you can check if the uplink status is active.
GET https://dashboard.meraki.com/api/v0/networks/{{networkId}}/devices/{{serial}}/uplink
"status": "Active",
VS
"status": "Failed"
ww^
"status": "Active",
VS
"status": "Failed"
Philip D'Ath
That did the trick thanks!
Philip D'Ath
I wish there was a way to all the API from a "front end" page, rather than having to do it from a back end.
It would be great if you could define a CORS domain in the API key section.
