SDK library Issue
Hi All,
There was nothing changed in my visual studio; I opened it today and saw this error. I tried to download Meraki SDK again with no luck.
Raphael_L
Meraki Community All-Star
What errors do you get when downloading and installing the Meraki python SDK ?
I dont see any error
obrigg
Meraki Employee All-Star
Is it possible that VS code is using a different virtual environment or an interpreter? That would explain why it's not recognizing "import meraki".
No, I always use the same folder and environment. I had to remove VS code and re install it for this to work.
