Analysis Engine is Not Running
Manuel Lopez Rivas
Frequent Visitor
Frequent Visitor
Hi Guys!
I´m looking for your help about an issue with an Cisco IPS (B-BEAU) that is showing the Analysis Engine=NotRunning
These are the SO and Version of my IPS:
Version: 7.0(6)E4
OS Version: 2.4.30-IDS-smp-bigphys
If I execute the show events command I get the following lines:
ct-sensorApp.650 not responding
evStatus: eventId=1326914865100530240 vendor=Cisco
  originator:
    hostId: XXXXXXXX
    appName: modprobe
    appInstanceId:
  time: 2013/07/13 02:11:05 2013/07/12 20:11:05 CST
  syslogMessage:
    description: Note: /etc/modules.conf is more recent than /lib/modules/2.4.30-IDS-smp-bigphys/modules.dep
The following lines show the result for the show status command:
XXXXXX# show health
Overall Health Status                                   Red
Health Status for Failed Applications                   Red
Health Status for Signature Updates                     Not Enabled
Health Status for License Key Expiration                Red
Health Status for Running in Bypass Mode                Red
Health Status for Interfaces Being Down                 Red
Health Status for the Inspection Load                   Green
Health Status for the Time Since Last Event Retrieval   Not Enabled
Health Status for the Number of Missed Packets          Green
Health Status for the Memory Usage                      Not Enabled
Health Status for Global Correlation                    Not Enabled
Health Status for Network Participation                 Not Enabled
Security Status for Virtual Sensor vs0   Green
Security Status for Virtual Sensor vs1   Green
Do you have any idea what's wrong here?
I'll appreciate any help about it,
Thanks folks!!!
Hi Manuel,
Pre-7.0.8 versions have issues with the latest signature updates, so most likely you will face this issue after every signature upgrade. So I suggest you to upgrade at least to 7.0.8 or 7.1.7.
Luis Silva
"If you need PDI (Planning, Design, Implement) assistance feel free to reach"
http://www.cisco.com/web/partners/tools/pdihd.html
Luis Silva
JonPBerbee
Level 3
Level 3
We have seen this happen occasionally on different sensors that we manage. This usually occurs after a new signature update and the way to resolve the issue is to reboot the sensor. Looks like your license is expired so maybe that is not the issue. If you reboot the sensor and the problem comes back right away you can try and downgrade the signature and see if that is the issue.  Otherwise you'll need to talk to TAC to get root cause.
Jon,
I'm going to follow the steps that you commented, I'll keep you posted!!
Thanks in advance!
Hi Manuel,
Luis Silva
Luis Silva
