Analysis Engine
lcuchisanmillan
Level 3
Level 3
The sensor IDS 4250XL 5.1 reports that the daemon AnalysisEngine has a status of not Runnnig. What does it mean? What i have to do? It is probably this is the source of the problem i have with the deployment of this sensor from the IPS Manager??
Thank you
jwalker
Level 7
Level 7
If the Analysis Engine is not running, the sensor will not analyze traffic and will therefore be useless (won't generate alerts..). To restart the analysis engine, make a service account then log into the service account and run the command below (you must su to root first).
/etc/init.d/cids restart
Hope this helps.
