ASA 5505 on a Stick Please Help!
missiongeek
Hi All, I am on here asking help from the internets today.  I have been assigned a task I am not prepared for, or don't have the expertise at all with ASA whatsoever.
I currently have a 2845 router connected to my asa 5505 on port 0/0.  Port 0/1 is connected to a switch the feeds to a bunch of other unmanaged switches.
Router-----Port 0/0 ASA5505 Port 0/1------Switch------ Many computers  (NO VLANS)
I want to do the following
Router----Port 0/0 ASA5505 Port 0/1-----Managed Cisco Swich----Unmanaged Switches
***I already have the managed switch configured for 802.1q trunking and all that other good stuff.
Here is my current config
hostname ASABLAHBLAH
domain-name BLah.com
enable password BlahEPW encrypted
passwd BPLAH encrypted
names
name 10.10.0.0 A-10.10.0.0 description INSIDE_NETWORK
name 10.10.0.5 A-10.10.0.5 description VPN_PLATINUM2
name 10.10.0.90 A-10.10.0.90 description VGSUPPORT
name 63.150.232.0 A-63.150.232.0 description OUTSIDE_NETWORK
interface Ethernet0/0
description VLAN 2
switchport access vlan 2
interface Ethernet0/1
description VLAN 1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
shutdown
interface Vlan1
description Inside
nameif Inside
security-level 100
ip address 10.10.0.1 255.255.252.0
interface Vlan2
description Public
nameif Public
security-level 0
ip address 68.x.x.x 255.255.255.224
boot system disk0:/asa824-1-k8.bin
ftp mode passive
clock timezone EST -5
clock summer-time edt recurring
dns domain-lookup Inside
dns domain-lookup Public
dns server-group DefaultDNS
name-server A-10.10.0.5
name-server 10.10.0.7
  domain-name Blah.com
same-security-traffic permit intra-interface
object-group service DM_INLINE_TCP_1 tcp
port-object eq www
port-object eq https
access-list NoNAT extended permit ip A-10.10.0.0 255.255.252.0 log critical
access-list in-out extended permit ip any any
access-list in-out extended permit tcp host 10.10.0.10 any eq smtp
access-list in-out extended permit tcp host 10.10.0.104 any eq smtp
access-list in-out extended permit tcp host 10.10.1.15 any eq smtp
access-list in-out extended permit tcp any eq www any eq www log
access-list in-out extended permit tcp any eq smtp any eq smtp
access-list in-out extended permit tcp any eq https any eq https log
access-list Public_1_cryptomap extended permit ip A-10.10.0.0 255.255.252.0 zzz255.255.248.0
access-list nonat extended permit ip A-10.10.0.0 255.255.252.0 xxx 255.255.248.0
pager lines 24
logging enable
logging timestamp
logging emblem
logging list SyslogEvents level alerts
logging console warnings
logging monitor errors
logging buffered emergencies
logging trap errors
logging history errors
logging asdm errors
logging from-address mauricio@terarecon.com
logging host Inside 10.10.0.250 format emblem
logging host Inside x.x.x.x format emblem
logging permit-hostdown
mtu Inside 1500
mtu Public 1500
ip local pool Pool 10.10.1.200-10.10.1.245 mask 255.255.255.224
ip verify reverse-path interface Inside
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-625-53.bin
asdm history enable
arp timeout 14400
global (Public) 1 interface
nat (Inside) 0 access-list nonat
nat (Inside) 1 0.0.0.0 0.0.0.0
access-group out-in in interface Public
route Public 0.0.0.0 0.0.0.0 63.150.232.1 1
route Public 172.16.0.0 255.255.248.0 63.150.232.1 1
timeout xlate 1:00:00
timeout conn 0:30:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
mac-list 500 permit 001c.2395.9ab5 ffff.ffff.ffff
aaa authentication ssh console LOCAL
aaa authentication telnet console LOCAL
http server enable
http 0.0.0.0 0.0.0.0 Inside
snmp-server host Inside 172.16.51.0 community ***** version 2c
no snmp-server location
no snmp-server contact
snmp-server community *****
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set chevelle esp-des esp-md5-hmac
crypto ipsec transform-set 3desmd5 esp-3des esp-md5-hmac
crypto ipsec transform-set terarecon esp-des esp-md5-hmac
crypto ipsec transform-set strong esp-3des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map dynmap 100 set transform-set 3desmd5
crypto map vpn 1 match address Public_1_cryptomap
crypto map vpn 1 set peer x.x.x.x
crypto map vpn 1 set transform-set 3desmd5 terarecon strong chevelle
crypto map vpn 100 ipsec-isakmp dynamic dynmap
crypto map vpn interface Public
crypto isakmp identity address
crypto isakmp enable Inside
crypto isakmp enable Public
crypto isakmp policy 1
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp policy 2
encryption des
hash md5
group 1
lifetime 1000
crypto isakmp policy 10
encryption des
hash md5
group 2
lifetime 86400
crypto isakmp policy 65535
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp ipsec-over-tcp port 10000
client-update enable
telnet 0.0.0.0 0.0.0.0 Inside
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 Inside
ssh timeout 60
ssh version 2
console timeout 0
management-access Inside
no threat-detection basic-threat
threat-detection scanning-threat shun
threat-detection statistics
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
enable Public
svc image disk0:/anyconnect-win-2.4.1012-k9.pkg 1
svc image disk0:/anyconnect-wince-ARMv4I-2.4.1012-k9.pkg 2
svc enable
group-policy DfltGrpPolicy attributes
vpn-tunnel-protocol IPSec l2tp-ipsec svc webvpn
username terarecon password vKhU6EpRuuCQRcyQ encrypted
username missiongeek password vrGUIr23/Frg5rdJ encrypted privilege 15
tunnel-group DefaultRAGroup general-attributes
address-pool Pool
dhcp-server A-10.10.0.5
tunnel-group x.x.x.x type ipsec-l2l
tunnel-group x.x.x.x ipsec-attributes
pre-shared-key *****
class-map type inspect http match-all asdm_medium_security_methods
match not request method head
match not request method post
match not request method get
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
  id-randomization
  id-mismatch action log
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect http
  inspect pptp
  inspect icmp
  inspect ip-options
policy-map type inspect http HTTP_inspection
parameters
  protocol-violation action drop-connection
class asdm_medium_security_methods
  drop-connection
service-policy global_policy global
smtp-server x.x.x.x
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
proposed solution
description VLAN 2
description LAN
no nameif
no security-level
no ip address
interface Ethernet0/0.2
vlan 2
nameif Inside
security-level 100
ip address 10.10.0.0 255.255.252.0
interface Ethernet0/0.3
vlan 3
nameif dev
security-level 100
ip address 192.168.3.1 255.255.255.0
interface Ethernet0/0.4
vlan 4
nameif wireless
security-level 100
ip address 192.168.4.1 255.255.255.0
description Primary Internet
nameif Public
security-level 0
ip address x.x.x.x 255.255.255.224
same-security-traffic permit inter-interface
nat (Inside) 1 10.10.0. 255.255.252.0
nat (dev) 1 192.168.3.0 255.255.255.0
nat (wireless) 1 192.168.4.0 255.255.255.0
static (Inside,wireless) 10.10.0.0 10.10.0.0 netmask 255.255.252.0
static (Inside,servers) 10.10.0.0 10.10.0.0 netmask 255.255.252.0
static (wireless,Inside) 192.168.3.0 192.168.3.0 netmask 255.255.255.0
static (wireless,servers) 192.168.3.0 192.168.3.0 netmask 255.255.255.0
static (servers,Inside) 192.168.4.0 192.168.4.0 netmask 255.255.255.0
static (servers,wireless) 192.168.4.0 192.168.4.0 netmask 255.255.255.0
PLEASE PLEASE HELP
Julio Carvajal
Not sure what the question is but you have an ASA 5505 where you would like to implement 802.1q
An ASA 5505 behaves (configuration speaking) as a L3 switch (SVI stuff and L2 physical ports).
So here is my example. I will use port fas 0/3 as a trunk link going to switch 1 and will trunk vlans 10,20 and 30.
Interface vlan 10
nameif Inside_1
security 100
ip add 10.10.10.1 255.255.255.0
no shut
interface vlan 20
nameif inside_2
ip add 10.10.20.1 255.255.255.0
no shut
interface vlan 30
nameif inside_3
ip add 10.10.30.1 255.255.255.0
no shut
interface fas 0/3
switchport mode trunk
switchport trunk allow vlan 10,20,30
no shut
That's it
Then configure security policies as you wish.
Note: To make this work on your device remember to rate my post hehe
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
