ASA 5506-X unable to use with Wireless Controller and lightweight access points - UDP 67 discarded
iancuv001
Hey guys,
I recentlly purchased 2 ASA 5506-X to replace Meraki MX50 appliances and I'm running into an issue. Basically UDP traffic including port 67 is being discarded inter VLAN
My configuration:
ASA-tunk port-SWITCH-trunk port-WLC
                                     -access port AP
The VLANS(subinterfaces) and DHCP server are on the ASA. The ASA has the inter VLAN command and also all VLANS have the same security number withput any ACLs
Log output attached
iancuv001
Adding log file
Some logs output
172.18.11.3|67|||Failed to locate egress interface for UDP from HB-Private:172.18.11.3/67 to 172.18.10.1/67
172.18.10.4|28359|255.255.255.255|5246|UDP request discarded from 172.18.10.4/28359 to HB-Management:255.255.255.255/5246
Have you allowed same security interfaces to talk  to each other with the "same-security-traffic permit inter-interface" command?
John
**Please rate posts you find helpful**
John,
I applied the following commands:
same-security-traffic permit intra-interface
