ASA 5510 ASDM browsing problem
shahid_duet
Level 3
Level 3
Dear boss
I am using ASA 5510. i can telnet to it from a PC and have permission for HTTP and ASDM.
OS: win server 2003; java 6; asdm 6;
when i browse it takes user and  password two times then show as attach picture and no browser appears.
i cant configure it graphically :
Help me plese.
shahid
4 Accepted Solutions
What are the exact versions that you are running on the ASA and ASDM.
When you actually try to load ASDM it has a java mug click on it and copy the output.
¨show run all SSL¨ would be nice and show version from the ASA to see if you have 3des enabled.
show resource usage resource asdm
On the ASA CLI you can run the next debug and copy the output and post it.
debug http
Value our effort and rate the assistance!
Could you try this instead?
no ssl encryption rc4-sha1 aes128-sha1 aes256-sha1 3des-sha1 des-sha1
ssl encryption aes256-sha1 des-sha1 3des-sha1
Problem: Exception in thread "SGZ Loader: launchSgzApplet" java.lang.NumberFormatException: For input string: "1 year 0"
This problem is caused by Cisco bug ID CSCsr89144 (registered customers only) in ASA running for more than one year with ASDM 6.0.3 or 6.1. As a result, ASDM cannot be launched.
Solution
This error can be resolved by reloading the ASA.
As you can see the ASA is been up and running for over a year;
DMZASA1 up 1 year 5 days
This is a good link for ASDM tshoot:
http://www.cisco.com/en/US/products/ps6121/products_tech_note09186a0080aaeff5.shtml
15 Replies 15
johnlloyd_13
Level 11
Level 11
It seems your browser and Java are ok.
Could you post 'show run http' and 'show run ssl' output?
debug http
Marius Gunnerud
Please post the output of the following commands:
show run http
show run aaa
show run | in asdm
Please rate all helpful posts
Please remember to select a correct answer and rate helpful posts
shahid_duet
Level 3
Level 3
All of ur required output ::
DMZASA1#  show run http
http server enable
http x.x.x.x 255.255.255.255 local
http redirect local 80
DMZASA1# show run ssl
DMZASA1# show run all ssl
ssl server-version any
ssl client-version any
DMZASA1# show run aaa
aaa authentication enable console LOCAL
aaa authentication http console LOCAL
aaa authentication telnet console LOCAL
aaa authentication serial console LOCAL
aaa authentication ssh console LOCAL
DMZASA1# show run | in asdm
logging asdm informational
asdm image disk0:/asdm-603.bin
asdm history enable
DMZASA1# debug http
debug http enabled at level 1.
DMZASA1# show ver
DMZASA1# show version
Cisco Adaptive Security Appliance Software Version 8.0(3)6
Device Manager Version 6.0(3)
Compiled on Thu 17-Jan-08 17:42 by builders
System image file is "disk0:/asa803-6-k8.bin"
Config file at boot was "startup-config"
Hardware:   ASA5510, 202 MB RAM, CPU Pentium 4 Celeron 1600 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash M50FW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
                             Boot microcode   : ☻CN1000-MC-BOOT-2.00
                             SSL/IKE microcode: ♥CNLite-MC-SSLm-PLUS-2.01
                             IPSec microcode  : ☺CNlite-MC-IPSECm-MAIN-2.05
Can u please suggest me what can i do for ASDM luncher open.
Can you add the 'des-sha1' keyword and try again?
hi johnlloyd
i added, but  no change.
regards
shahid
Could you post the complete 'show version' output please?
DMZASA1#  show ver
0: Ext: Ethernet0/0         : address is 0021.d871.820e, irq 9
1: Ext: Ethernet0/1         : address is 0021.d871.820f, irq 9
2: Ext: Ethernet0/2         : address is 0021.d871.8210, irq 9
3: Ext: Ethernet0/3         : address is 0021.d871.8211, irq 9
4: Ext: Management0/0       : address is 0021.d871.820d, irq 11
5: Int: Not used            : irq 11
6: Int: Not used            : irq 5
Licensed features for this platform:
Maximum Physical Interfaces  : Unlimited
Maximum VLANs                : 100
Inside Hosts                 : Unlimited
Failover                     : Active/Active
VPN-DES                      : Enabled
VPN-3DES-AES                 : Enabled
Security Contexts            : 2
GTP/GPRS                     : Disabled
VPN Peers                    : 250
WebVPN Peers                 : 2
AnyConnect for Mobile        : Disabled
AnyConnect for Linksys phone : Disabled
Advanced Endpoint Assessment : Disabled
This platform has an ASA 5510 Security Plus license.
Serial Number: JMXxxxxxxxxxx
Running Activation Key: 0xaf01406a 0xf0524a87 0xbc 0x4cc 0xcf90
Configuration register is 0x1
Configuration last modified by xxxx at 22:38:33.943 UTC Fri Nov 29 2013
DMZASA1#
java info is missing, can you please get that information for me please, if you forgot what I asked please refer to my last post
Solution
shahid_duet
Level 3
Level 3
Dear all
I did :
Then tried but no result.
After reloading  i get luncher is ok.
May be reload is the bests solution.
shahid
You can upgrade to not encounter the issue in future.
