ASA 5510 ccna security lab setup problem
sany98
Level 2
Level 2
I'm heaving problem with my lab/asa setup. I can access (ping/https) asa/asdm from my home pc 192.168.1.15 but i cant ping or telnet to subnets 192.168.2, 192.168.3 and 192.168.4. I want to be able to access and configure my routers from my home pc, i know that it has something to do with outside to inside and other way but don't know ho to fix it.
PC1, 2 and 3 have internet access from the ASA. PCs can ping to each other and ping to inside interface. RIP is enabled on all routers and on the ASA and all routers have default route to ASA. Here is problem that I cant access the ASDM on outside interface 192.168.1.133 and ping doesn't work either. Can anyone please help me?
My lab is located in the basement so that's why i want to be able to access everything from my home pc.
28 Replies 28
LAN only IP settings. On Wireless only name, password etc.
Then I would suggest looking through the user guide / configuration guide for your router and if those don't provide any clues perhaps contact the router support team.
Please remember to select a correct answer and rate helpful posts
I've updated the router firmware to more advanced and managed to put static routes to inside subnets and now everything works. Just one new minor problem. I've installed Cisco ACS on subnet 192.168.3.0 but can't access it from home pc 192.168.1.0 on outside network. I've added the http and ssh lines on both outside and inside interface but it doesn't work. Only works from inside networks 192.168.2-4.
You said you added ACL entry for HTTP, but ACS uses HTTPS.  Update your ACL entry and test again.
I meant HTTPS but that was not the issue. Windows firewall was blocking the traffic. When i disable FW it works, i can access Cisco ACS on 192.168.3.133 and other routers using https on inside networks. When FW enabled nothing works. Whats weird is that HTTPS to asdm on 192.168.1.133 works without problem even with windows firewall enabled (maybe because its on same network). I've tried to add rule in firewall to allow inbound connections for 443 but it doesn't work. This is so frustrating, you solve one problem but the other one occurs :(..
If anyone knows how to fix this issue with windows firewall please help because it's driving me mad. I don't want to disable firewall every time I need to change/access something.
You mean windows firewall on the PC you are initiating the connection from? or the windows firewall on the PC you have installed ACS on?
Yes, windows firewall on Home-PC blocks the traffic. When firewall disabled, everything works.
If you go to windows firewall > Advanced Settings and in the window that pops up go to outbound rules and add a new rule for the programs you are using (ASDM and the terminal emulator).  Then test.
ASDM works. FW blocks telnet and https to inside networks. Ive tried to add inbound and outbound rules on ports but will try you suggestion and open for programs.
i have now tried with both inbound and outbound rules for internet explorer and putty and it didn't worked.
I believe that firewall blocks everything that is not on same subnet, but how to allow that traffic in firewall it looks like its impossible.
Check out this link...seems to be the same issue you are experiencing
https://superuser.com/questions/1087392/windows-firewall-blocking-ssh-to-secondary-subnet
THANK YOU KING! I have googled for 2 days now and I don't know how i missed that one! Problem was that after you create rule you need to edit the same rule to add subnets and other stuff. Thank you once again!
