ASA 5510 Problem with Compact Flash
Hello friends 🙂
My company has got ASA 5510 without CF. I inserted a few CF but without any success.I tried to use CF from my ASA 5505, too. I tried to use format, and fsck, but everything was the same. Can I use the same image from ASA 5505 on ASA 5510 ?
Error log:
mount: mounting /dev/hda1 on /mnt/disk0 failed: no such file or directory
and
Evaluating BIOS Options ...
Launch BIOS Extension to setup ROMMON
Cisco Systems ROMMON Version (1.0(11)5) #0: Thu Aug 28 15:23:50 PDT 2008
Platform ASA5510
Use BREAK or ESC to interrupt boot.
Use SPACE to begin boot immediately.
Launching BootLoader...
Default configuration file contains 1 entry.
Searching / for images to boot.
No images in /
Error 15: File not found
unable to boot an image
Searching /
for images to boot.
No images in /
CCNA R&S, CCNA Security
12 Replies 12
Marius Gunnerud
An asa 5510 cannot run a 5505 image.  I suggest you boot into ROMMON and load the asa 5510 image from a tftp server.  Once the ASA is booted format the CF and then copy the ASA5510 image into flash and configure the image to boot from using the "boot system" command.
http://www.petenetlive.com/KB/Article/0000792
Please remember to select a correct answer and rate helpful posts
Hi, I tried via tftp,  I found image for ASA 5510, and I uploaded via tftp, but I can not copy from tftp to flash memory. I tried fsck, and format, but without any succuess.
Why are you unable to copy from tftp to flash? are you getting an error?
What ASA image version are you trying to use?
Hello 🙂
Output from booting via tftp:
Insufficient flash space available for this request:
  Size info: request:32 free:0  delta:32
open or write(ffsdev/2/write/32) failed
Could not initialize system files in flash.
config_fetcher: channel open failed
ERROR: MIGRATION - Could not get the startup configuration.
INFO: MIGRATION - Saving the startup errors to file 'flash:upgrade_startup_errors_201603140917.log'
ciscoasa# dir flash:
Directory of disk0:/
1164   -rw-  196         09:17:27 Mar 14 2016  upgrade_startup_errors_201603140917.log
1162   drw-  0           09:17:27 Mar 14 2016  coredumpinfo
1157   drw-  0           09:17:24 Mar 14 2016  crypto_archive
1147   drwx  0           09:17:16 Mar 14 2016  log
0 bytes total (0 bytes free)
ciscoasa# dir disk0:
You can boot ASA5505 image on ASA5510,5520, 5540 as well till version 9.1.6/9.1.7 as of now(9.2.x of 5505 is made available for 5505 and other -x series ASAs).
It looks like a corrupt compact flash or may be you need to format this from ASA5505 itself and then use.
or
Try to place this Flash again on ASA5505, load the image let say asa825-k8.bin and then see if this works on ASA5510.
It looks like CF got corrupted.
Hope it helps.
Akshay Rastogi
Remember to rate helpful posts.
Hm, now I think ASA has problem with CF reader. This is only normal  reason. Can I format CF on Cisco Router 2801. Does both of  the Cisco devices use the same file system?
I believe not. You would receive the bad magic error i guess. You could try that though.  However try the one i mentioned earlier.
Akshay Rastogi
Error :
Accessing tftp://192.168.100.10/asa832-k8.bin...!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
%Error copying tftp://192.168.100.10/asa832-k8.bin (Not enough space on device)
ciscoasa#
There is your problem...not enough space.
Have you upgraded your flash to 2 GB?  This is the recommended size if you intent to run an ASA version that is 8.3 or higher.
Hm, but image asa832-k8.bin, has size about 25MB. ????
Now I format my 2GB to 512MB, but I will format again.
Hello friends,
ASA has hardware problem, We got second device, and now everything is fine 🙂
Thank you 🙂
