ASA 5510 problem
jorgRamakers
Is it possible to configure an asa 5510 as an inline transparent firewall and use it also as an VPN gateway?
How does the config looks like?
Jorg
Richard Burts
Jorg
I do not have an authoritative answer and if anyone does I would hope that they jump in. But I do not see how the ASA could be transparent as a firewall but be non-transparent for VPN. As a VPN end point I would think that it would have to be a visible layer 3 device.
Rick
Rick
not possible.
you can't do vpn's in transparent mode.
As Rick and Steven indicated " not posible ".
On this link refer to unsuported features when running transparent firewalling mode.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008089f467.shtml#unsupp
Jorge Rodriguez
