ASA 5525 Firmware Upgradtion and Revert(rollback) process
netbeginner
Level 2
Level 2
Dear Friendz,
Currently we are using ASA 5525 in Active-Standby pair (Firmware - asa922-4-smp-k8.bin) and planning to upgrade the same, aware about the firmware up gradation process but would like to know about rollback (revert or downgrade steps) . If require in case of any service issue with or due to new firmware.
5 Replies 5
johnlloyd_13
Level 9
Level 9
hi,
you could copy the new image on the ASA flash and retain the current asa922-4-smp-k8.bin image.
just manipulate between the boot system commands if you plan to roll back.
see helpful link and sample below:
http://ccnpsecuritywannabe.blogspot.com/2015/06/asa-file-system-and-bootvar-command.html
for upgrade:
no boot system disk0:/asa922-4-smp-k8.bin
boot system disk0:/<NEW IMAGE>.bin
for roll back:
no boot system disk0:/<NEW IMAGE>.bin
Adding to what johnlloyd_13 has suggested, also take a backup of the current configuration as there is a change in the config structure on version 9.1.3 and above so you can refer following link:
http://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/116685-problemsolution-product-00.html
R.Seth
Thanks John and R.Seth,
Could you please also share what are the standard services need to verify after firmware upgrade on ASA to ensure that everything is working fine.
There is not a specific service that you can check, once the upgrade is done you can run show version and confirm if the device has upgrade to correct version.
You can check:
>> The failover status if you are running failover on ASA.
>> Check CPU usage.
Also if you have a monitoring system then you can check if the status of device after upgrade is same as expected in your network.
You should also check if the ASDM you are using is compatible with ASA version, in case it is not then upgrade your ASDM as well.
Refer following link for compatibility:
http://www.cisco.com/c/en/us/td/docs/security/asa/compatibility/asamatrx.html
Hope it helps!!!
R.Seth
Mark the answer as correct if it helps you in resolving your query.!!!
hi,
adding to what risseth have mentioned, issue a show run and ensure all CLI lines are intact using the new ASA image.
also, since you've got a active-standby ASA setup, you want to make sure that it's working. see useful link:
http://ccnpsecuritywannabe.blogspot.com/2013/12/active-standby-failover-on-asa.html
please help to rate and mark as answered.
