ASA 5540 telnet connection issue
Max ma
Community Member
Hi ALL,
I met a strange issue about ASA 5540 telnet issue ,I can telnet FW successfully ,but after i log in a few minutes ,FW will be no response ,then the telnet will interrupt .  It's very strange ,I checked CPU ,Memory ,logs ,everything looks fine .
9 Replies 9
johnlloyd_13
Level 11
Level 11
hi,
what's your telnet timeout config?
could you post show run telnet?
Hi ,
Thanks for your reply.  I think this shouldn't be telnet timeout issue .
My telnet timeout config "telnet timeout 300"
Can you get these outputs:-
show resource usage
show process cpu-hog
show process
show ver
Thanks and Regards,
Vibhor Amrodia
Please review attachment
Max ma
Community Member
Sorry ,there are a lot of issues on format ,so i uploaded outputs in attachment ,please kindly review .
BTW ,SSH is working normal .
I remember ,I met this issue before ,but i forget how did i resolve this issue or how it be normal .
Thank you !
Max
Max ma
Community Member
Is there anyone can help me ?
Thank you !
I went through the outputs and the only thing i see which might be related would be the denied connections on the ASA evice.
Rest all the things are fine. I also see that the ASA device is running a very old and unstable code :- 8.21 , so i would recommend an upgrade to the 8.2.5 if possible the latest interim and i think that should take care of this issue.
Thanks and Regards,
Vibhor Amrodia
Hi ,
Get it .I will try  to update IOS version .  Thank you very much !
Best Regards !
Max
Thanks Max
