ASA 8.2 Packet tracer syntax for outside traffic
marktaylor47
hi,
what will be packet-tracer syntax to check if outside interface traffic is allowed to get to inside networks
thanks
mark
24 Replies 24
Hello Mark,
I mean right now all we are testing is a HTTP connection to the 10.1.1.57 ( in this case pointing to the outside interface on port 80) from 10.170.0.5
access-list acl-outside extended permit ip 10.170.0.0 255.255.255.0 host 10.8.8.1
That will do it,
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Hi Julio,
it worked, still can't ping from 10.1.1.57
asa# packet-tracer input outside tcp 10.170.0.5 1025 10.8.8.1 80
Phase: 1
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
static (inside,outside) tcp interface www 10.1.1.57 www netmask 255.255.255.255
  match tcp inside host 10.1.1.57 eq 80 outside any
    static translation to 10.8.8.1/80
    translate_hits = 0, untranslate_hits = 4
Additional Information:
NAT divert to egress interface inside
Untranslate 10.8.8.1/80 to 10.1.1.57/80 using netmask 255.255.255.255
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group acl-outside in interface outside
Phase: 3
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 4
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect http
service-policy global_policy global
Phase: 5
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
Phase: 6
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
Phase: 7
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 8
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 545, packet dispatched to next module
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: allow
asa#
thks
mark
Hello Mark,
What do you mean by
What are you trying to do now??
Remember to rate all of the post that help
Julio Carvajal
Hi Julio,
I am trying to access 10.170.0.5 & other IP's in outside-acl,  I can ping from firewall but not from 10.1.1.57.
This is the server which all remote devices in outside-acl will access. I can only ping 10.8.8.2 from 10.1.1.57.
thks
mark
Hello Mark,
If you want to ping outside users from inside hosts
do nat (inside) 1 0 0
Then try it.
Julio Carvajal
Hi Julio,
it works :-) , thank you for all your help, can you please explain what this command did & access from outside networks to 10.1.1.57 will work now ?
should I remove these commands as they were added for testing:
thks
mark
Hello Mark,
You are trying to connect from the lowest security level interface ( outside) to the highest security level interface (inside).
So by default the traffic will be denied unless you configure an ACL allowing the traffic on the outside interface.
So we will need to create one ACL for this traffic.
Now let's talk about the NAT.
There are different kinds of NAT rules. Ones will work unidirectional and others bidirectional.
In this case as the connection will be innitiated on the outside world we need one that allows Inbound connections on our ASA, and we will use a port-mapping rule to do it. So a Port-forwarding ( will be uniderectional and inbound) so that is what we will do
static (inside,outside) tcp interface www 10.1.1.57 www netmask 255.255.255.255 says:
If the ASA receives a packet on port 80 on the outside interface forward it to the host 10.1.1.57 on port 80, this if the connection is allowed via an ACL.
So the ACL access-list acl-outside extended permit ip 10.170.0.0 255.255.255.0 host 10.8.8.1 is required.
That's it! please check your inbox here on the cisco support comunity
Julio Carvajal
Hi Julio,
Thank you for all your time & help.
mark
Hi Julio,
One more question, if I need access-list for 10.170.0.0, then I will need to add all outside networks to it ?
& can you explain" nat (inside) 1 0 0 "
thks
mark
1) Yes, but the ACl should point to the Natted IP address.
2)Nat (inside) 1 0 0  is used to translate all the internal users to the outside interface when they attempt to connect to an outside user
Remember to rate all of the helpful posts
Julio Carvajal
