ASA 8.2 static nat problem?
M.alzubaidy
Community Member
Hi all
I have two active and standby ASA 5520 V(8.2) when I trying to configure static NAT by
static (inside,outside) interface 172.16.1.156
it work properly, but when I use this command instead of first one
static (inside,outside) 212.126.122.45 172.16.1.156
it dose not work!! and I need it to use another public IP for another private server because I have many servers inside each server need public ip, so any suggestion please??
note :
1- my inside network (172.16.0.0/16) and outside (212.126.122.40/29)
2- attachment conftain show run for both my ASA
many thanks..
Philip D'Ath
Meraki Community All-Star
Did you create a rule (on the outside interface) allowing traffic into 212.126.122.45?
many thanks for replying, yes I create that
access-list outside_access_in extended permit ip any any
access-list inside_access_in extended permit ip any any
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
Philip D'Ath
I don't think you have anything wrong.  Try the change again, and then maybe something like:
clear xlate
Also try waiting 10 minutes.  It smells like something has cached something.
If you do a "show arp | inc 212.126.122.45" it definitely comes back with nothing (meaning that the IP address is not in use), correct?
First you can try to take the packet tracer on the ASA to check whether the ASA is allowing the traffic or not.
packet-tracer input outside tcp <source IP> 12345 212.126.122.45 80 detail
If you do not see any error in this then you can take the capture on the outside and inside interface of the firewall to check whether traffic is passing through the firewall or not. This needs the actual traffic to test.
cap capin interface outside match tcp host <internet IP> host 212.126.122.45 eq 80
cap capout interface inside match tcp host <internet IP> host 172.16.1.156 eq 80
to view the capture output:
show cap capin
show cap capout
Shivapramod M
Please remember to select a correct answer and rate helpful posts
