ASA A/S Failover issue with OSPF routing
Hi All,
I have a couple of ASA 5520 ( 9.1 version) in A/S failover connected to Core (4500X). We need to configure routing : I have no problem with static routing but when I configure ospf after some seconds the standby goes in active ( though the real active remains active) and I don't know why.
We have a SVI on core side
interface Vlan700
description ASA-LAB
ip address 10.50.50.82 255.255.255.248
ip ospf dead-interval 3
ip ospf hello-interval 1
on ASA side
interface GigabitEthernet1/0
media-type sfp
nameif inside
security-level 100
ip address 10.50.50.81 255.255.255.248 standby 10.50.50.83
the  Standby becomes immediately active after ospf configuration and  show failover history, I have:
10:31:10 CET Nov 9 2017
Standby Ready Just Active ACK not received for failover message
10:31:11 CET Nov 9 2017
Just Active Active Drain ACK not received for failover message
Active Drain Active Applying Config ACK not received for failover message
Active Applying Config Active Config Applied ACK not received for failover message
Active Config Applied Active ACK not received for failover message
10:31:27 CET Nov 9 2017
Active Cold Standby Failover state check
10:31:29 CET Nov 9 2017
Cold Standby Sync Config Failover state check
this happens more times until the standby reboots
ASA-LAB#
******REPLICATION OF CONFIGURATION FROM ACTIVE TO STANDBY UNIT IS INCOMPLETE,
TO PREVENT THE STANDBY UNIT TAKING OVER AS ACTIVE WITH A PARTIAL CONFIGURATION,
THE STANDBY UNIT WILL NOW REBOOT*******
*** --- SHUTDOWN NOW ---
Could you please if there is something to know about failover and ospf?
Thanks a lot
Alessandro
Hello @alessandro.pasinetti
Very interesting problem. As per behavior and logs, looks like OSPF is interfering on the failover communication.
How does failover link looks like in your topology?
Does failover IP address is on the same range of Network addressing ?
OSPF was activated in all firewall interface?
-If I helped you somehow, please, rate it as useful.-
