ASA and WebVPN port forwarding issues
d.rocco
Hi all,
i'm running the latest interim release of asa 8.0(4)23 and Cisco ASA is configured for auto start web vpn port forwarding.
On every PC, when it try to load the Application Access Plugin, i obtain the following error from java console:
Error reading localization: java.net.SocketException: Unconnected sockets not implemented.
I find that WebVpnRegKey6-"domain-name".dll is not a valid win32 application with 0KB.
With VPNConcentrator all is working fine, so i don't think that could be a client issue.
Any feedback?
Thanks' Diego
wong34539
Level 6
Level 6
I think the port forwarding no longer working with Java 12 update
You may use the following workarounds:
Use Smart Tunnels or downgrade Java JRE version. In the Control Panel open Java, turn off "Keep temporary files on my computer".
