ASA Backup Routing problem
judaly
Community Member
Hallo all,
I have been asked to look at other locations ASA 5506 Firewall.
When the primary ISP is down that cannot connect to a number of external hostnames.
Under Configuration -> DeviceSetup -> Routing -> Static Routes there are only three listed
and these are for VPN subnets.
I am assuming from this that there is no default route set at all and only works as it is there or it was removed when the default was gone temporarily.
How can this be correctly patched that if the primary ISP is down again external hostnames are reachable?
And how can this be achieved on the ASDM and not on the command line.?
thanks
Julian
balaji.bandi
