ASA can not ping outside behind router. Help!
klncy2014
Hello guys,
   I have simple setup lab in a GNS3.  I having a problem pinging from the ASA to the outside world.  If I'm in the rotuer, I can ping fine(ping 4.2.2.2), I'm getting reply back. But no luck on the ASA itself.  For now I just wanted to get the ASA to ping outside the cloud. Then later I play around with the host pc. I really  appreciated if someone can help me out. Thanks all!
Here are my configs on ASA n Router.
ASA Version 8.4(2)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface GigabitEthernet0
nameif outside
security-level 0
ip address 10.10.10.1 255.255.255.0
interface GigabitEthernet1
nameif inside
security-level 100
ip address 172.168.1.1 255.255.255.0
interface GigabitEthernet2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet3
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet5
shutdown
no nameif
no security-level
no ip address
ftp mode passive
object network inside_mapped
subnet 172.168.1.0 255.255.255.0
object network internal_lan
pager lines 24
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 10.10.10.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect icmp
  inspect icmp error
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
crashinfo save disable
Cryptochecksum:10910835b2de0a54ad502ba3e5c1f9dd
: end
ciscoasa#
Cisco 2600:
interface FastEthernet0/0
description To Internet
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description inside edge router
ip address 10.10.10.2 255.255.255.0
ip nat inside
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 192.168.137.1
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 1 permit 172.168.0.0 0.0.255.255
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
Jouni Forss
You havent configured any NAT on the router for the 10.10.10.0/24 network.
When you directly ICMP from the ASA then it will naturally first do a route lookup and see that the destination IP address is behind "outside" therefore it will use the "outside" interface IP address as the source IP address for the ICMP Echo message.
You will need to add an ACL line to the NAT configuration on the router
access-list 1 permit 10.10.10.0 0.0.0.255
This should add the network to the Dynamic PAT configuration on the router to my understanding
Remember to mark the reply as the correct answer if it answered your question.
- Jouni
Jouni Forss
- Jouni
Once again you helped me out!!  Perfect thank you!  I can ping to the cloud now.
Now, I want to setup the host to allow to ping outisde
Do I need to setup NAT on the ASA or the router, in order for the host to ping out?
thx
ken
