ASA Load balancing/failover? (info question)
rhnewmark
I haven't read anything about load balancing or failing over between two WAN connections so I assume the ASAs do not support it but I wanted to try and get a definitive answer. Thanks.
nefkensp
Level 5
Level 5
The ASA 5505 supports dual-ISP mode in the plus license. This means that the default gateway or anything beyond the deault gateway is monitored. Once a failure is detected, the floating default gateway to the fallback ISP is initiated.
This works for outbound connections.
Hope this helps
