ASA on Multi-Network
woodjl1650
Level 5
Level 5
I have three LANs connected to my ASA, all have internet access, but I am not able to ping or access any of the LANs on the inside network.  Can you please advise on where I went wrong?
ASA Version 8.2(3)
hostname ciscoasa
enable password DQucN59Njn0OjpJL encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.5.1 255.255.255.0
rip send version 1 2
rip receive version 1 2
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
ftp mode passive
access-list 100 extended permit ip 192.168.1.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list 100 extended permit ip 192.168.2.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list 100 extended permit ip 192.168.1.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list 100 extended permit ip 192.168.3.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list 100 extended permit ip 192.168.2.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list 100 extended permit ip 192.168.3.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list ripACL_FR standard permit 192.168.1.0 255.255.255.0
access-list ripACL_FR standard permit 192.168.2.0 255.255.255.0
access-list ripACL_FR standard permit 192.168.3.0 255.255.255.0
access-list ripACL_FR standard permit 192.168.5.0 255.255.255.0
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
route-map HomeRoute permit 1
match ip address 100
match interface inside
router rip
network 192.168.1.0
network 192.168.2.0
network 192.168.3.0
network 192.168.5.0
redistribute static route-map HomeRoute
default-information originate route-map HomeRoute
version 2
distribute-list ripACL_FR in interface inside
route outside 0.0.0.0 0.0.0.0 68.108.10.1 1
route inside 192.168.1.0 255.255.255.0 192.168.5.1 1
route inside 192.168.1.0 255.255.255.0 192.168.2.1 1
route inside 192.168.1.0 255.255.255.0 192.168.3.1 1
route inside 192.168.2.0 255.255.255.0 192.168.5.1 1
route inside 192.168.2.0 255.255.255.0 192.168.1.1 1
route inside 192.168.2.0 255.255.255.0 192.168.3.1 1
route inside 192.168.3.0 255.255.255.0 192.168.5.1 1
route inside 192.168.3.0 255.255.255.0 192.168.1.1 1
route inside 192.168.3.0 255.255.255.0 192.168.2.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.5.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.5.5-192.168.5.36 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
Cryptochecksum:14debb742c0a6f337f9f5005a22c9a14
: end
ciscoasa#
26 Replies 26
What do each set of (x.x.x.x) R1(x.x.x.x) mean?  Is that IP address of R1 then gateway?
R1
IP Address = 192.168.1.1
Default Gateway = 192.168.5.1
WAN IP Address = 192.168.5.3
R2
IP Adress 192.168.2.1
WAN IP Adress = 192.168.5.4
R3
IP Adress = 192.168.3.1
WAN IP Adress = 192.168.5.2
Internet IP = 68.108.12.XXX
Hello Jonathan,
What I mean is that you have 4 diferent networks on the same interface, the only way to set this up is with Layer 3 devices  splitting the broadcast domains and the networks.
but to do this each router will need to have a default route pointing to the ASA.
Do you understand what I mean
192.168.1.1 ---R1--192.168.2.2----192.168.2.1---R2------192.168.3.2----192.168.3.1--R3--192.168.5.2----192.168.5.1-ASA--
I hope this show you my point of view,
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Can you explain the 192.168.1.1 R1 192.168.2.2....and so on, I don't get where those IP are supposed to go.
Maybe is that  I dont understand the topology....
At this moment are you able to ping the interface from all the PCs in the diferent networks?
Julio Carvajal
I can not ping, but all have internet access.
Here is the running config:
ASA Version 8.2(3)
hostname ciscoasa
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
same-security-traffic permit intra-interface
pager lines 24
mtu outside 1500
mtu inside 1500
arp timeout 14400
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd enable inside
webvpn
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
Cryptochecksum:8c43eed321b244660819baf3ee4e5368
: end
ciscoasa#
Yeah my biggest doubt is that you are telling the ASA that if he wants to get into  192.168.1.0 he has 3 different next hops. and the same thing for 192.168.2.0 and 192.168.3.0 but checking the Diagram that is not possible.
Julio Carvajal
So this is a no go?
At least for me Know, maybe someone has another opinion but in my case I would rather use a Switch connected directly to the ASA and then split the network into 192.168.1.0 192.168.2.0 192.168.3.0
I hope this help you Jonathan
Julio Carvajal
How do you do that, I have a 2900xl switch.....
Sent from my iPhone
Thanks for all the help thus far.  LIke I said a littl bit ago, I have a 2900XL and  NetGear FS518 switch.  Could you please tell me how to configure it with switches?
